1 - 4 of 4 Posts
Need some help disconnecting the fuel injectors & fuel line to the fuel rail. Any pointers?
Pull the fuse for the fuel pump to use the fuel in the fuel rail by starting it a couple of times.
Disconnect the fuel injector wiring harness by lifting on the red clips and pinching and pulling out.
Unbolt the 4 black mounting posts connecting the fuel rail to the manifold.
Fuel rail supply line is just pinch and pull off.
Lift up the fuel rail and injectors will come out attached to the fuel rail.
Thanks brother!
1 - 4 of 4 Posts
