How do i add transmission oil?
17K views 7 replies 6 participants last post by  Don Fox
We had a leak, had to change gasket and need to add more oil obviously , but I don't know from where to put it.
Any help is appreciated.
Umm, what model year do you have and what engine? After 2011 the trans went to a ZF which has a very distinct and difficult fill process that's required.
But, of course she hasn't bothered to reply with the year or engine of her vehicle.
#8 ·
@ newkid:
The '14 Durangos have the 8 speed transmission, which does not use ATF+4. The older Nag1 5 speed uses the ATF+4.
If you are looking for how much it holds, check the owner's manual. The required fluid is pricey, and the level check/filling procedure is crazy!
