2019 Durango GT Plus- . 2 problems:
Has less than 300 miles on it. Makes a high pitched fan like noise. Seems to be coming from under the right side of the steering wheel. Sometimes it goes off after a few minutes, other this doesn't go off. When it does go off it has a "winding down" sound and the sound only varies when you shift gears.
Second problem is that I have an amber start/stop light with an exclamation point always visible. The message center says start/stop unavailable and turning it off and on does not make a difference and no light show on the control whether it is on or off.
Purchased it a long way from home and will be taking it to a more local dealer tomorrow.
Any ideas at least on the noise? (The warning light is pretty self explanatory)
