1 - 2 of 3 Posts
IndyDurango
· Premium Member
Now that I'm dependent on relays more than ever, I think I should carry a spare or two.
If one failed before, I could pull the fog light relay for temporary use, etc. Now on the e-fan setup, I'm tapped into the key-on fuel pump relay and tapped into the AC-on air conditioner relay. I'd like to carry a few spares just in case. Afterall? the ones in there are factory originals.
I'm referring to the under the hood fuse box relays.
Where's the best place to pick a few up to stash in the cubby? Expected costs? TIA!
IndyDurango
Discussion starter · #3 ·
Update: 2000 5.9L D Underhood Relays
Mopar part #4671168
Retail: $12.52
Street: $11
Description, same size/color and imprinted numbers on the top row (4671168E.) On the lower row of numbers, the last character on my stocker originals is an "M". The replacements are a "V" (72472M vs 72472V.) Usually this indicates a change in supplier. Thus? the stocker originals are stamped with "Siemens". The replacements say "TYCO".
These relays are the ones on the 2000 that are interchangeable between the fuel pump relay, AC Condenser relay, fog light relay, etc. YMMV.
Since my wiring on the electric fan controller is piggybacked tapped into the fuel pump and AC relay on my D, I wanted a spare or two just in case.
IndyDurango
1 - 2 of 3 Posts
