ok I had a bad misfire. obdII tester said misfire on cyl 3. I changed cap and button and wire. started it up and its running like its missing again and engine light came on. I ran test again and it says #5 injector circuit open, I said to myself that can't be right. I checked make sure all wires to inj ok cleard code and restarted soon as I gave it gas the engine light came back on and obd tester says #6 injector circuit open.
I reset the computer and after a min of idleing it mil on #6 again
the D is a 2000 5.9 bout 97k on it. it was cold had sat for 2 days when it was started. any info on this would be gratefull.
thanks
thanks
