21 - 40 of 111 Posts
Thanks keegantimber. I took your advice and started following the wires from the battery and I found it.. it was staring at me the entire time. I was looking for the fuse block that is part of the remote positive jump terminal under the hood. Then i took it out and saw that the 150A fuse was blown. I was able to run down to the Dodge dealership and get a replacement. Installed the replacement part (68089468AA) and plugged the batteries back up and the lights came back on.. I turned on the truck but I still have the check engine light on and the radio display doesn't turn on..Ugh!
View attachment 110395 View attachment 110396
Please help me figure out where this piece is. My 2019 Durango gt is having the same problem and I’m trying not to spend thousands at the dealership.
How did you get this off?
Going to assume you have this figured out by now but posting for others.
There's two tables on the side and the cover just slides off.
In all my years I've never shorted battery terminals out. I was under the false impression that each battery was isolated since it's supposed to be an auxiliary battery. When in fact they are both running to the same terminals it just seems that the positive terminal on the aux battery is intended to make sure the voltage can be read in order to allow the start/stop to be enabled on startup.
I don't follow, where is this 2nd Battery? There is one underneath the Passengers seat which is the main battery, so where is the other one?
Sorry for what could be a stupid question but: I hate the start-stop system and I even read there are ways to permanently bypass/disable it. I didn't have chance yet to study wiring diagrams. Anyone would know if is possible to take the aux start-stop batter OUT permanently, just taking it away and never replace/reconnect it. If this would just give me the yellow "start-stop unavailable" dash light but not affecting anything else, I'd definitely do it. Thanks for any comments or suggestions!
I believe someone makes a start/stop bypass kit. Try searching the forum for it.
Here is a link to everything Aux battery related.
This link goes to a PDF which describes ESS operation.
Now worries.. I'm going to get to the bottom of this.. I did find a blown radio fuse that is located in the battery compartment.. thanks to @41Deacon for his post.. it helped.. here's a photo View attachment 110399
Hello I am having similar problems as you. My vehicle asked me to pull over because my vehicle was going to shut off. I replaced my main battery and we found the positive terminal fuse box is burn out. I still have to replace that, however my mechanic was able to start my Durango. Once started everything was fine but my dashboard will not light up. Do you happen to know where the dashboard fuse is located?
This is the burnt box. However the fuses did not break and I am hoping once this is replaced everything is well and running back to normal. My mechanic mentioned it is a possibility the shock that happened reached the inside components of the alternator so I’m keeping faith beacuse I do not have over $500 laying around for a new alternator
The jumper post fuses are apparently a common failure when the battery (or batteries on the V6) fail. The V6 versions with ESS have a somewhat complex relay setup that uses an intelligent battery sensor to determine which battery to use (PCM controls a relay called the PCR). My guess is if one of the batteries has a high internal resistance it can draw a lot of current thru the system causes fuses to pop.
More info on the ESS here.
BTW if you are interested in learning more you can access the FSM here. Gives wiring diagrams and sometimes diagnostic steps.
