HeLP!... Ugh i feel like an idiot.
1 reading
80K views 110 replies 29 participants last post by  Tin Foil Hat
So its been a year since I've purchased my 2018 Durango GT. Haven't had a single issue.. then the battery died on me. I put plugged the truck to charge but quickly noticed that the battery wasn't holding the charge and kept loosing volts. my dealer warranty had expired so I went to replace the batteries and found that I had two batteries. Took them to Autozone and got two new batteries. I installed the main battery with out a problem but when I installed the auxiliary battery sparks flew and the whole truck went dark. I wasn't too sure what happened and I started doing some research and found that the auxiliary battery they gave me has the positive terminal on the right and the negative on the left.. backwards from the original auxiliary battery... I know.. I'm an idiot. I need help now. Is there a main fuse or ECU fuse that would blow in times like these?
Ark:
The smaller battery is for the autostart system. I would do some investigating in the fuse panels under the hood. Hopefully, you have just blown one of larger ones..
Reactions: wvhemis
I would check all of your electrical systems in the DD to make sure none are drawing power when the vehicle isn’t running. I had a similar problem to you on my boat- the new Bluetooth radio system I had installed was drawing power when the boat wasn’t running (days at a time), and the main battery would be dead by the time we got there. This also ruined the batteries and I had to replace them. Maybe a similar thing caused your batteries to go bad.
DuRonbo is correct. I was just as surprised..
I went back to Autozone and the gave me the right auxiliary battery and I installed. I was able to turn the truck on for a couple of minutes but it definitely didn't work properly. My guess is that it wasn't getting enough juice from the batteries. As soon as I disconnected the auxiliary battery again everything went dark again.. then with the main battery connected only, I check the terminals under the hood and was still getting enough voltage. Something is interrupting the flow to the rest of the truck.. All the fuses in the fuse box.. any thoughts?
I've also read about high current fusses but I don't know where they are located in the truck. Does anyone know?
110383
110384
Just trying to help out...Chrysler used to use fusible links on main power wires. They look just like a wire and are usually soldered into the main harness. Sometimes they had a rubber tab. They were usually located near the starter. Maybe have a look there?? And start tracing some main wires. Should be red.
Sent from my SGH-I337M using Tapatalk
quick search cuz I was curious. Found this which I'm guessing would be mounted in fuse box
Thanks keegantimber. I took your advice and started following the wires from the battery and I found it.. it was staring at me the entire time. I was looking for the fuse block that is part of the remote positive jump terminal under the hood. Then i took it out and saw that the 150A fuse was blown. I was able to run down to the Dodge dealership and get a replacement. Installed the replacement part (68089468AA) and plugged the batteries back up and the lights came back on.. I turned on the truck but I still have the check engine light on and the radio display doesn't turn on..Ugh!
110395
110396
First. Good luck with those issues. Hopefully it's a simple fix for both. A DTC might help you with engine light. Just a guess that it might be something to do with charging system? Or maybe the code set as a result of the blown main fuse and you can just clear it?
Thanks for posting your findings! I learned something today![emoji4]
Now worries.. I'm going to get to the bottom of this.. I did find a blown radio fuse that is located in the battery compartment.. thanks to @41Deacon for his post.. it helped.. here's a photo
110399
#31 ·
Sorry for what could be a stupid question but: I hate the start-stop system and I even read there are ways to permanently bypass/disable it. I didn't have chance yet to study wiring diagrams. Anyone would know if is possible to take the aux start-stop batter OUT permanently, just taking it away and never replace/reconnect it. If this would just give me the yellow "start-stop unavailable" dash light but not affecting anything else, I'd definitely do it. Thanks for any comments or suggestions!
#32 ·
I believe someone makes a start/stop bypass kit. Try searching the forum for it.
#34 ·
Here is a link to everything Aux battery related.
This link goes to a PDF which describes ESS operation.
#35 ·
Now worries.. I'm going to get to the bottom of this.. I did find a blown radio fuse that is located in the battery compartment.. thanks to @41Deacon for his post.. it helped.. here's a photo View attachment 110399
Hello I am having similar problems as you. My vehicle asked me to pull over because my vehicle was going to shut off. I replaced my main battery and we found the positive terminal fuse box is burn out. I still have to replace that, however my mechanic was able to start my Durango. Once started everything was fine but my dashboard will not light up. Do you happen to know where the dashboard fuse is located?
#39 ·
This is the burnt box. However the fuses did not break and I am hoping once this is replaced everything is well and running back to normal. My mechanic mentioned it is a possibility the shock that happened reached the inside components of the alternator so I’m keeping faith beacuse I do not have over $500 laying around for a new alternator
#40 ·
The jumper post fuses are apparently a common failure when the battery (or batteries on the V6) fail. The V6 versions with ESS have a somewhat complex relay setup that uses an intelligent battery sensor to determine which battery to use (PCM controls a relay called the PCR). My guess is if one of the batteries has a high internal resistance it can draw a lot of current thru the system causes fuses to pop.
More info on the ESS here.
BTW if you are interested in learning more you can access the FSM here. Gives wiring diagrams and sometimes diagnostic steps.
#43 ·
Actually, the batteries should not be jumped at their terminals and only at the jumper posts in the engine bay. Also with the aux battery it is very easy to misjudge which is + an -, as the post below shows.
