- $600 in stock parts
- $580 in labor at a local wrench
- start to finish in under 4.5 hours :!:
Issues: The replacement blower fan while running is what I'd consider double the noise level now. The stocker replacement gasket on the blower housing was typical gasket material while OEM installed gasket was gooey. I think I'll turn the fan on high and test around the gasket with a flame to look for vacuum leaks and if discovered, seal 'em up.
The evap was toast, the heater core very dirty and leaky (didn't know until the tell tail green signs of antifreeze was inside the housing.) The blower rattled as low speeds ever so slightly so while in there? it only made sense to replace it too.
IndyDurango
IndyDurango
