1 - 6 of 6 Posts
If I replace chrome headlights without led strip to another headlight with led strip, will the strip turn on?
you will need a new connector..2011 to 2013 are different connectors...but yes it will work if you redo it
Discussion Starter · #3 ·
Mine is a 2014 but has the chrome headlights without the led strip at the bottom...would I still need a different connector?
If it doesn't have the LED strip, you will need to connect it somehow. I'm not familiar with how it's powered, be it though a separate connector or if it uses a single plug.
1968 Dodge Dart GTS, 340/727
2016 Dodge Durango Limited
I just check the wiring diagram and its the same connectors for the base lighting and the premium system...just swap out to the newer headlight assembly
1 - 6 of 6 Posts
