1 - 20 of 28 Posts
Someone has finally come through with a 2 row radiator for 2012 up Durangos and Grand Cherokees. I asked Mishimoto about this at LS Fest and was told that one was in the works. I checked the website recently and it's there along with an installation video into a Grand Cherokee SRT. I don't really have many miles on mine but noticed that the factory 203° thermostat runs as low as 199° sometimes. It would be nice to be able to hold that temp most of the time. Towing in hot weather must really drive that temp up with the factory 1 row unit.
Just encase anyone is interested, this was not easy to find on their website, but it there:
This works on the 3.6L V6 up to '15 as well as the 5.7L applications. I had my factory HD unit (part of the trailer towing package) replaced under warranty. If the current one ever starts leaking at the side tank O-ring gasket joint like the first one did - most likely inevitable, this maybe what I would buy (expensive though) and use as a permanent fix.
This is great news. I was talking to the rep from Wizard Cooling about one for the Durango at the Chrysler Nationals in Carlisle, PA last year and was given a quote of $750 plus the cost of an oem for mock up. Definitely on the parts list now.
This radiator is awesome, great craftsmanship.
109211
109212
109213
Reactions: LIDurangoRT
Installed it yesterday.
Test fitted the radiator, then dressed it out with AC condenser & fan.
109453
109454
109455
109456
109457
Reactions: DaveG
I replaced the AC condenser as well and was doing some other work so I needed the entire front clear.
I don't tow, but preparing to run it at Maple Grove dragway and add a ProCharger in the future.
Yes it has the towing package with HD cooling.
Can't see it because the AC condenser is in front of the radiator.
109515
You can get another 5% off this radiator now, use code SPG2020 at checkout. Brings the total down to $607.95
I can't answer that for you, it would depend if you tow long distances, hot climate up steep terrain.
Like I said earlier, I was getting ready to run 1/4 mile test & tune and some grudge races at Maple Grove Raceway, but that is set aside until this Coronavirus lockdown is over.
1 - 20 of 28 Posts
