Gaskets on PPH headers
7.7K views 24 replies 8 participants last post by  Kevin_Rants
Just thought I'd give a heads up. One of my gaskets blew between the collector and the Y-pipe. Might want to keep an ear and rear tuned for it in case it's a bad batch of gaskets. Bought a pair of Mr. Gaskets, hopefully these will last longer. If you need some to keep as a spare (sell for $7 a pair) let me know.
greg
No. Since mine blew and I didn't have a lot of time, I just went with a name I recognized (Mr. Gasket.) But since I have to drop the pipes to remove the tranny pan to get to the filter/band, I'll no doubt have a chance to look into them.
As to re-using them? they're only $7 a pair so it's not worth the risk. What you can't do is use any sort of liquid gasket such as Permatex as they won't stand up to the heat generated.
Thanx for the heads up though. With my luck there won't be a dealer here and shipping will be $389 :roll:
greg
#8 ·
I'd definitely recommend not reusing any type of exhaust gaskets
Definitely my take as well.
I just spoke with Mike Leach and passed on that there were at least 2 boown gaskets. He said to make sure the pipe's ends are flush and, other than that, he'll keep an eye out on that batch of gaskets. If anyone else has a blown gasket or other problems, please call Mike Leach or, if you prefer, post here and I'll forward it to Mike.
greg
In your case, no John. But for others, after some moderate use, they should never reuse them.
The most important thing with header gaskets is alignment and retightening!
Make sure they're aligned square to each other and retorque them after several heat and cool cycles as the slightest leak will develop into a bad leak!
#14 ·
You must find a way to retorque Grasshopper. Natural movement and expansion and contraction will occur for a bit of time.
All header bolts! Both on the heads and the collectors.
#23 ·
Headers
Not torqued you guys, tight! Header and flange gaskets don't fail if tight and mated properly. I've never had one fail. My formula is, after installation check all the bolts
  1. After first heat cool cycle
  2. After 1 week
  3. After 2 weeks
  4. After 1 month
  5. After 6 months
  6. Once a year or every tune up
Bolts stretch and gaskets compress. It's critical that the flanges be mated properly. I usually hit the flanges with an impact butterfly and hold the nut with a wrench. Header bolts are 5/16 12 point and best tightened by hand with a small box end wrench. Just tighten until the resistance curve gets steep. You don't want to break one.
Bill
#24 ·
That's what I did as there's no way to torque all the flange bolts. They were tight yet two people had blown gaskets. I passed it on to Mike Leach and he said to let him know if that ocurrs and which side (driver or passenger.)
greg
#25 ·
Re: Headers
  2. After 1 week
  3. After 2 weeks
  4. After 1 month
  5. After 6 months
Bill
I've got a set of two Craftsman wrenches just for my headers - just haven't touched them in 3 years. The first 2 years though, they were "tightened" quite a few times!
