About 31,000.I'll be keeping an eye on mine. Just filled it last night when filling all my gas cans for my tractor. Out of curiosity, what kind of mileage is everyone experiencing this issue at?
Mine is very loose in the open position. It's like the hinge is only connected on the top. I'm sure this could cause misalignment issues.Make sure the door is aligned. Mine was not which is what cause the issue for me.
Just picked up a used 2014 Durango that also has this issueNext time it sticks look at the gap around the door. Mine was off by a tiny bit, but it was enough. Since I discovered this slight misalignment, every time I close the door, I make sure all is lined up. I have not had the door stick since.
Mine too!! Should push the dealer to replace this as it was broken when delivered to meI just had the fuel door and spring replaced under warranty. The door would not pop open, so I used a credit card to pry it open. Another symptom was the fuel door was very loose when in the open position (felt like it was hanging on by a thread).
I know this is a really old thread, but just looked at mine.Mine too!! Should push the dealer to replace this as it was broken when delivered to meHe's a smaller used car dealer specializing in 4x4 trucks mostly. It's got 69k, so past the factory warranty for that
Sent from my ASUS_Z00AD using Tapatalk
I have a '15 Citadel & it does this too. Slackness in the hinges or cable is my guess. My fix is to pry a corner with my wallet & hit the button again. Voila! Works every timeI have only had to fill my D up 3 or 4 times, but every time I do, I can not open the fuel door. I push the button and everything works fine with the release mechanism, but the door won't open. I have to have a family member hit the button while I pry it open with my finger. The only thing I can think of is since the tank has no cap, as the gas is used it creates a vacuum. Since the door does have a seal around it, it hold that vacuum and doesn't open unless pried open. Has anyone else experienced this???
