1 - 4 of 4 Posts
I have a 2005 Dodge Durango with a 4.7 engine. I have notice that fluid is bubbling up from a small pin hole in a connector between a metal pipe and rubber hose. Its located just about the power steering reservoir and leads to a fan on the front drivers side of the engine. I am wondering if this is normal? It seems to leak more when I run the air conditioner at high. Any suggestions? Thanks
Not normal, That is an A/C line, you are blowing refrigerant out. You should get it fixed before the content is all gone which will causes more issues in your ac system.
x2 on fixing the leak.
1 - 4 of 4 Posts
