Yup, a few members here already have, they will probably chime in when the see they post.Can I swap a 5.7L out for a 392 hemi in my 2017 DD rt
Yes, check out my YouTube videos. Channel is called Tony Harmsen.Can I swap a 5.7L out for a 392 hemi in my 2017 DD rt
Any problems or notable things I should be aware off?Yes, check out my YouTube videos. Channel is called Tony Harmsen.
It was very well worth it. It only took a day and a half. And it was a very easy swap, plug n play... literally. PM me if you have questions. Hers the first video to get you started.
2014 Durango 392 Engine Swap Part 1
Series of short (crappy) videos of my experience doing the swap of an SRT 392 Hemi from a 2020 Jeep Grand Cherokee SRT into a 2014 Dodge Durango RT RWD. It's...youtube.com
Hey Tony-Yes, check out my YouTube videos. Channel is called Tony Harmsen.
If your Durango is a 2014-16 it will work, but will need to be tuned. If it’s newer, you will need to have it unlocked, then it can be tuned. I’m not sure about the 11-13. It has a different style of ecm, I believe. I would definitely use the 8 speed if you can.Hey Tony-
Just purchased a 2015 Challenger 6.4 motor. Had a quick question regarding the computer. Did you have to swap out computers as well or have the stock computer flashed? I will more than likely be swapping the 5sp tranny to the 8sp stock transmission unless I am advised it to.
Thanks for the reply Tony!If your Durango is a 2014-16 it will work, but will need to be tuned. If it’s newer, you will need to have it unlocked, then it can be tuned. I’m not sure about the 11-13. It has a different style of ecm, I believe. I would definitely use the 8 speed if you can.
Tony- were you able to use the oil pan on your swapped engine? Was told by a few individuals that I might need to pick up an oil pan from a Durango SRT?If your Durango is a 2014-16 it will work, but will need to be tuned. If it’s newer, you will need to have it unlocked, then it can be tuned. I’m not sure about the 11-13. It has a different style of ecm, I believe. I would definitely use the 8 speed if you can.
