U0101-LOST COMMUNICATION WITH TCMDoes that mean that they are still present? Or they were fixed? This are all the codes that were stored when they changed the battery
For a complete wiring diagram, refer to the Wiring Information.
- When Monitored:
- With the ignition on.
- Battery voltage between 10 and 16 volts.
- Ignition Off Draw (IOD) fuse installed.
- Totally Integrated Power Module (TIPM) is configured correctly.
- Set Condition:
Bus messages not received from the Transmission Control Module (TCM) for approximately 500ms.
Possible Causes |
CAN BUS CIRCUITS OPEN OR SHORTED |
DTCS RELATED TO BATTERY VOLTAGE, IGNITION, OR VIN MESSAGES |
TOTALLY INTEGRATED POWER MODULE POWER AND GROUND |
TIPM NOT CONFIGURED CORRECTLY |
TOTALLY INTEGRATED POWER MODULE (TIPM) |
MODULE THAT SET THIS DTC |
U0415-IMPLAUSIBLE DATA RECEIVED FROM ABS
Theory of Operation
The messages sent on the CAN bus are distinguished by an identifier (ID). Each CAN ID is defined to contain a certain number of bytes. The Transmission Control Module (TCM) verifies that it has received the proper number of bytes for each ID.
- When Monitored:
Continuously with the ignition on, one valid CAN ID received at least once, and no U0002-CAN Bus Off Performance DTC present. - Set Condition:
When the TCM detects an incorrect CAN ID from the ABS control module.
Possible Causes |
FCM CAN BUS DTCS PRESENT |
ABS DTCS PRESENT |
TRANSMISSION CONTROL MODULE (TCM) |
