Just joined the forum. Having a problem with my Durango and thought this might be just the place to get some answers and or advice.
Engine light on my 2000 Durango 4x4 with a 4.7 engine and 147000 miles.
Checked the fault codes, shows number 305 and 205 misfire detected-cylinder number 5.
Possible Causes:
1. Spark Plugs
2. Coil
3. Vacuum Leak
4. Injector Bad (number 5)
5. High or low pressure regulator
6. Powertrain control module
7. Fuel return line blocked
8. Check TPS and circuit for failure
The first thing that I did was to put in new plugs, that were needed and reset the computer. The Durango ran just great for about 3 days before the light came back on. I reset the computer about 3 more times with the same results. Prior to the light cumming on the Durango runs perfect, It acts like maybe a misfire happens then the light comes on, at that point the truck runs like it's running on 7-clinders. Now I can't see where it could be a bad Injector, because when I reset the computer all is good for another day or two. So before I just start replacing everything on the list which can get costly maybe someone on the forum might have experienced the same problem or others might have some suggestions.
Possible Causes:
1. Spark Plugs
2. Coil
3. Vacuum Leak
