Anyone know? I need to swap the short block and was wondering if I can use a 2006 engine in my 2005? maybe they made improvements? Will the sensors/senders still work?
I don't want to go pull it out only to find out it isn't compatible.
Different
il pump(rockauto says same), starter(rockauto shows different!), flex plate, transmission(dont care), torque converter(dont care), water pump, thermostat housing....
Same: Oil pan, oil pressure switch, oil pickup, cylinder head is 05-07, head gasket(01-07), timing 03-06, exhaust manifold(04-08), intake 05-07,cam(05-07), intake valve 2000-2009, crank damper(2000-2009), crank(05-08).
flexplate(04-09), rod bearing(05-09). piston assembly(04-07), engine mount, air temp sensor(01-09), cam sensor(04-06), crank sensor(02-07), oil pressure switch(03-06), radiator(04-06)
Oil pump doesnt scare me... The starter, flexplate does... But crank is the same so it should take the 05 flexplate and starter then? Rock auto
Different
