1 - 4 of 4 Posts
Have 2011 D and my driver window will go down or up when pushing the window button but will only travel about two inches at a time. I have to release button and press again and it will travel another two inches in the desired direction. Also cannot push and release as Auto down/up is not working. Any idea if the power switch is the issue or could it be the motor or something else?
sounds like that switch went bad
Wonder if the auto up/down needs a recalibration? the procedure might be in the owner's manual (it is on my '07)..
Mine does that unless I press really hard on the switch, I plan on replacing it in the near future. It gets a lot of use.
roog
1 - 4 of 4 Posts
