Good evening Yall, so I have a 14 Durango Limited. I will start here, with since I have owned it less then a month I noticed a slight air leak in the top of where the window goes into the top of the door ok, no biggie then noticed as if the phelt was missing from the inside of the door towards the bottom significant gap between panel and glass(door panel is pushed all the way). Moving on today, was pulling into work, had not messed with the window at all and heard a loud POP noise as if someone hit my door. I looked around and there was nothing, pulled into my parking spot, and my buddy came over and I rolled the window down as I hit the button it would not automatically go down, then once it was down it had a loud grinding noise, so I went to put the window up, and it made a loud grinding noise again and the window would barely move. I had to force it with the help of my buddy, once it was up if I hit the up button once it was up the window started to slide down as if it wasnt connected and continued to grind. No prior issue till today. any answers? Regulator, motor, off track.
