Couple weeks ago the 46re with around 100k miles, decided to stay in 3 gear, reverse worked too, no error codes, transmission fluid was good and no signs of damage in the oil pan. So I parked it and did some Internet search on the subject.
Found lots of input including "NO LOW GEAR (MOVES IN 2ND OR 3RD GEAR ONLY)
1. Governor Circuit Electrical Fault. 1. Test with DRB® scan tool and repair as required.
2. Valve Body Malfunction. 2. Remove, clean and inspect. Look for sticking 1-2 shift valve, 2-3 shift valve, governor plug or broken springs.
3. Front Servo Piston Cocked in Bore. 3. Inspect servo and repair as required.
4. Front Band Linkage Malfunction 4. Inspect linkage and look for bind in linkage. " on Automatic Transmission Diagnostic Chart - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums and on some other internet pages.
In storage I already have a complete 46RE rebuild kit from https://www.700r4l60e.com, that I ordered around 3 years ago to rebuild what turned out to be a A500/42RE instead of A518/46RE. I then ordered the A500 rebuild kit, rebuilt the A500 and kept the A518 rebuild kit in storage.
This A518 rebuild kit includes the Transgo JR shift kit.
So I decided to overhaul the Valve Body, change/upgrade the electrical sensors and Install the Tansgo TFOD-Jr Shift Kit. Inspect the bands while at it and decide from there If rebuild the whole 46RE.
I ordered the master solenoid service kit from A518 / 46RE Master Solenoid Service Kit Fits 1998 & 1999 Models
Very happy, the kit also included a rubber pan gasket, which makes maintenance/service a lot quicker and cleaner.
Here are the instructions, it is sometimes handy to have an extra copy.
Removing the check ball (yellow) is not a Transgo shift kit modification.
After removing it, 1-2 is almost too firm for stop and go traffic, for my taste, I will probably put the check ball back in one day, to test the difference.
There is also an old video here TransGo-Video Assistance that covers the removal of the VB.
