While swapping out from the winter wheel /tire set to summer wheel /tire set, I referred to both the .pdf available on the Mopar app and hard copy of the Owners Manual and the only wheel torque spec I could find is 130 ft-lb. I recently searched the forum and found that SRT models wheel torque spec is 110 ft-lb.
What are you other DD TNG owners using as a torque spec? I am going to assume the DD TNG SRT components warrant using the 110 ft-lb torque spec.
Now, that the lug nuts are sitting @ 130 ft-lb, do I just back off each lug nut and re-tighten to 110 ft-lb? Is there any specific procedure that I should follow under the circumstances?
Thanks for the input.
Pat
Pat
