DD 2021 SRT - rear fog light problem
1.3K views 8 replies 5 participants last post by  Yulas
Hello, first of all, hello to you all.
I have a problem with the rear fog light procedure in a 2021 Durango. Everything seems to be fine, the switch works in 4 sequences but the BCM does not supply voltage to the harness. The active test works from the application (jscan), but not from the button. Has anyone encountered such a case? I come across a simple change procedure everywhere - no one has described a similar case anywhere
DD 2021 SRT
Since most of us are in the US where we don't have such lights you'll need to wait for one of your neighbors to check in.
Reactions: Ollie Crow
There is a setting the BCM for rear fog lights, have you enabled it?
I’ve seen it while looking through AlfaOBD, but never tried enabling it.
#8 ·
hello, unfortunately not. the problem in my opinion is in the BCM version, I read a bit about the BCM version in various Dodge models, some of them require modification for such conversion. I did it classically on a separate switch (0.5 h of work). I recently did a Jeep GC - everything took a moment.
