My wife's Durango's heat has been blowing like warm, just a hair above room temp. It's winter in Wisconsin and with four small kids, it's not great. Back in September I had replaced the thermostat thinking it would solve the problem, but it didn't help. Heat still blowing lukewarm. I noticed the passenger side vents were not responding at all to temperature changes, and after some research, decided to remove the glove box to inspect the blend door actuator and gear. Sure enough, the gear was broken. I replaced the gear and the passenger side responded to temp changes again. Unfortunately, the heat still doesn't get hot. Just lukewarm.
The next day a light came on the dash - red lightning bolt between two backwards parenthesis, but went away later on. Her check engine light also came on with the following codes:
P2181
P0128
since the thermostat had a lifetime warranty, I received a new one for free and installed it tonight. Still no improvement, at least at first. I let the truck idle in the garage and topped off coolant, and squeezed the radiator hose repeatedly. Slowly the coolant temp sensor rose to normal operating temp (195-200ish), though it took like 20 minutes. I hopped it and drove around for a few minutes. As I drove around, the coolant temperature dropped steadily all the way back down to 145-150. I went back home and let it sit and idle again. The coolant temperature once again slowly rose to operating temp. I'm at a loss as to why the coolant temperature drops when driving, and rises while idling. I did this idle up to temp, then drive around thing 3-4 times. The heat in the cabin is blowing way hotter now, but does start to slowly cool off as I drive around.
My only guesses at this point are 1. Still some air in coolant system or 2. The coolant temperature sensor is bad.
Does anyone have any ideas? And please don't say thermostat. This is the 2nd brand new thermostat I installed. Thanks for any help you can provide!
P2181
P0128
