So in doing some research online ive noticed the Durango has a weird 203° F Thermostat, not an issue. However im noticing if I just start the car and drive around a little my temp doesnt go above 188 but if I sit idle somewhere the temp climbs to 210° then the thermostat opens and the Temp drops. Is my thermostat going bad? Also if I have my temp set to 72° in the cab if im going slow ill have little heat only slight warm.
The only thing I can think of is Thermostat going or I have air in my cooling system.
