1 - 3 of 3 Posts
Hello. My 2004 Dodge Durango Limited will show the check oil light when the engine is cold after I first turn it on. After I turn it off and restart it's totally fine. This happens in the colder months or if it gets chilly in the morning. Any advice would be appreciated, thank you.
Maybe a bad sending unit
X2 on the sending unit. Same thing happened to me a week or two after I brought it home. I picked up a new sender from AZ. It's a fairly easy install. If I recall correctly, I did it from above, and removed the air filter housing for better access.
It threads into the block right near the oil filter.
1 - 3 of 3 Posts
