Changing the bolt pattern.
13K views 18 replies 11 participants last post by  Diesel Durango
I guess I worded my last ques. wrong. The wheels I want aren't available in the 6/4.5 bolt pattern. Is it difficult and expensive to change to a more common pattern?
Lug configuration change
You can buy billet adapters with any pattern you want. A little spendy though
For the street, I guess that adaptor plates wouldn't be too bad. It tends to give you a slightly frog legged look, depending on wheel offset. Adaptor plates are known to break. Other than that it could get expensive, with custom axles and new discs/drums as needed.
That's what I figured. Probably cheaper to just get a set of wheels re-drilled and then seal up the original holes for strength.
I love Mopar, but it sucks how nothing is ever available for the vehicle I have. I've owned 3 mopars and I dealt with the same issues on every vehicle. You find what you want then its not made for your motor or bolt pattern.
Unfortunatel it's probably best to just Pick out a different set of wheels
:cry:
Can anyone please tell me why I waited 9 months for my rims? Well becuase until the new Toyotas came out with a 6 x 4 1/2 nothing was available. And no you can't have mine! :naughty: :naughty: :naughty:
greg
#8 ·
Greg,
Contact this guy, FRED GOSEKE (pronounced Go-Ski.) He makes billet wheel adaptors. When I was having all those damn Get Screwed Motorsports fitment problems with those friggen' Viper Brakes, Fred was able to make adaptors for the Durango to make them fit.
Here's a link to his website:
http://www.wheeladapter.com/home.asp
Whatever you need, he can make it for you. Tell him Mark with the Silver Durango sent you. I'm not sure he'll remember me, but he should remember my truck.
Good luck Bruddah!
greg said:
Bro' NOW you tell me this?? OK OK, if they don't come this weekend I'll look him up. Thanx! You comin' by again this way?
greg
Yes,
We'll be renting in the North Shore during the last half of August.
Mark
Drilling extra holes in a set of rims is asking for disaster. It really weakens the wheel webbing in the wheel center.
I'm hearing you can buy the rims not drilled for lugs, the problem I see with those, you must be perfect to get the pattern drilled into those or your balance will be off and further problems, if done wrong. You must have a reputable machine shop do this.
#14 ·
Agreed the weight of our vehicles will destroy them
Wheels
I think it'd be cool to have a single center nut like the F1 cars.
Hmmmmmm.
Only if we combined it with built in jacking system
#19 ·
you can get wheel adapters from 6x4.5 to 6x5.5 (chevy/toyota/jeep all use this on some vehicles)
I run 5x4.5-5x5.5 adapters on my Jeep Grand Cherokee, haven't had any problems with shearing lug nuts or anything. I got them from a guy on eBay?I forget which one, but it was like 180 shipped for 4.
