1 - 3 of 3 Posts
I wanted to go with a more power battery so I am thinking about up-grading to an H8 from a H7. has anyone done it? If so any issue with it?
Here are the specs from the same battery manufacturer on the H7 & H8 batteries. The key issue would be the added 1.5" length and if it would fit in the well under the front passenger seat;
H8
top right post (+)
900 CCA
150 min
48 lbs
height 7.50"
length 13.94" (too long?)
width 6.94"
H7
top right post (+)
800 CCA
140 min
43 lbs
height 7.50"
length 12.44"
width 6.94"
H8
top right post (+)
900 CCA
150 min
48 lbs
height 7.50"
width 6.94"
H7
top right post (+)
800 CCA
140 min
43 lbs
height 7.50"
length 12.44"
width 6.94"
Thanks I ended up sticking with the AGM H7......when I saw how big the H8 was I got nervous.....went Platinum
1 - 3 of 3 Posts
