Hello all -
Hoping someone can point me in the right direction....been working on a 2000 Durango, 5.9L. Originally we we getting a P1491 code; after much troubleshooting, narrowed it down to the PCM - which we replaced through an aftermarket supplier; we are no longer getting that code. After replacing the PCM, we started getting a P0123 error - and after replacing the TPS, we no longer get that code. We are also now getting a P1493 error, which seems to indicate a battery temp sensor failure. Now granted, I admit that failure could have been caused by the removal of it when working some other replacements, but after a 2nd inspection of the sensor itself, it looks to have no damage externally. The fuel gauge will bounce intermittently (at random) from E to F to E; the oil pressure gauge also stays maxed out - even with the engine off, but the ignition on.
It just seems odd that we're seemingly having all these sensor indicator issues at the same time - or is it? Is this a common issue? One of the original symptoms was that the radiator cooling fan isn't coming on (even with the A/C on) at all. The relay has been replaced, and I have verified the cooling fan will working by jumping the relay socket pins. I found that the FSM does have a procedure for troubleshooting the radiator cooling fan - but it appears to be a procedure for when there are currently no engine codes active.
On a different note, after the PCM was replaced we were seeing issues where the engine would start but not stay running unless it was being throttled. I could feather the throttle and get it to idle, but after a quick tap on the accelerator, the engine would stall and quit. Today I disconnected the PCM connectors, and coated them with dielectric grease and re-seated the plugs. We did not see the idling issue after doing that - but not sure at this point if that made a difference or if it was just coincidence.
I apologize for what feels like rambling, but was just trying to toss out everything (for the most part) that has been done. At this point we are planning to replace the battery temp sensor to address the P1493 code.
Does any of this make sense or ring a bell with anyone? One of my questions among the others is that if a PCM goes bad, can it take some of the other sensors with it?
Thanks,
James
Thanks,
James
