1 - 2 of 2 Posts
Dodge Durango MY 2015 3.6 WD Limited with LPG Prins VSI 2.0 alternative fuel system.
Hello Dodge drivers.
Today or for a while now my two LED brake lights have failed. I was approached today in the shopping car park about the missing brake lights. The third brake light works. In the BC fault memory no faults due to brake light and not in the cockpit either. The fuses seem ok too. The manual says that the LED lights can only be exchanged by dodge service. Has anyone had similar problems with the LED brake lights in the Durango my15?
Discussion Starter #2
The LED brake lights are working again. There were 2 thick cables loosely connected to the fuse box and caused this failure. Unfortunately, I cannot say which exactly those were. It had nothing to do with the conversion to Germany either. Everything is all right again.
Reactions: Don Fox
1 - 2 of 2 Posts
