That's OK, Pennzoil is owned by Shell....so just buy Pennzoil.Well, I wondered why the Rotella truck gas I posted above was becoming hard to find….thought it was supply issues like everything else. Seems it’s discontinue. Just found this.
Wow! That’s clean!The results speak for themselves Pennzoil Platinum full synthetic 5W-20. This oil had lower than normal wear running oil samples when I hit 100K . This oil was used for 95% of the life of the vehicle. Sold it privately at 136K miles and the purchaser was thrilled to see these reports. Oil filters were from K&N
I've never experienced any of the above issues on any of the Hemi's I've owned in the past 10 years, and that's 5 of them. They all get 5w30 RedlineOn using 5W30 oil
"It's important to know this engine uses 5W-20 engine oil. If the wrong oil is used, fault code P1521 can be set, and the vehicle may show symptoms of a shudder - similar to a torque converter shudder - when the MDS system is activated and deactivated. Other symptoms may include MDS performance codes or engine misfire codes."
But that's an average of only 2 yrs of ownership...I'm at 16 yrs and 8 yrs....265,000 and 145,000. 5W20 working fine.I've never experienced any of the above issues on any of the Hemi's I've owned in the past 10 years, and that's 5 of them. They all get 5w30 Redline
Yep... Someone else has experienced the noise using Pennzoil?To the 60% of you using the Pennzoil 5W20, I hope you have better luck using it in your 5.7 than I did. In my '06 Hemi Daytona, I tried it, and even the Ultra Platinum, and found both very noisy at cold start-up, and noisier at idle. Same issue when I tried the 5W20 even in our 2.4L Jeep. Switched to Mobil 1 EP, and much quieter in both.
In our new '21 DD 3.6, 1st oil change I used Mobil 1 EP 0W20, and very happy with cold start-ups all winter. I really wanted to like the Pennzoil, but after trying in multiple engines a couple of times, it just makes sense to me that any brand of oil that produces more noise will cause more wear.
Nope, I had just the opposite using Mobil 1...more noise than Pennzoil in my non-VVT Hemi.Yep... Someone else has experienced the noise using Pennzoil?
So, you are on the Pennzoil team. Yeah, you are right, but always is good to know the experience of everyone using some kind of brand. Seems like Pennzoil is a strong winner on those engines.Oh boy! An oil thread! 🍿😁 This one is pretty civil, I must say. Things usually get pretty heated!
I'm not going to sway anyone one way or the other with what I use. I'll just say I've been working on engines of all kinds for decades, and I've used them all. Clean oil is good oil, regardless of the brand. That said, there are wild variations in additive packages from one brand to the next. I ran Pennzoil for decades in my old V8's for hundreds of thousands of miles without an issue. I still run it in my '86 Grand Marquis that has leaked out of the rear main seal for the past 19 years. No point in wasting expensive Amsoil on a leaker. She's got 286k miles on her with zero signs of slowing down yet! You could argue that this is built in a different, much better quality time, and I'd say you're 100% right - this car is still on the original transmission, rear end, and in-tank electric fuel pump (first year of multi-port FI).
I've known people running cheap Walmart Tech 2000 (or whatever it;s called now) oil for over a decade, and they're still running.
But if you're towing, and when you're not, you've got your foot to the carpet every single time you leave from a stop, then Amsoil really can't be beat, especially for 10k mile plus oil changes. Oil analysis is a must, though. Not because the oil can't handle it, but because some engines just make trash over the course of running and might contribute to higher than normal wear.
I always stuck with Pennzoil, but I've run Castrol GTX, Quaker State, and some ultra cheap crap in my oil burners / leakers in the day. My '85 Monte Carlo used to burn a quart every 100 miles. I used to buy cases of Sunoco oil at ADAP Auto Parts for .77 cents a quart, lol. That car used to make people roll up their windows in the summer if they were unlucky enough to stop at a light next to my tailpipe. At idle, it pumped CLOUDS of blue out ... then when I jumped on the throttle when the light turned green, I couldn't see anyone behind or beside me. Good ol' days!So, you are on the Pennzoil team. Yeah, you are right, but always is good to know the experience of everyone using some kind of brand. Seems like Pennzoil is a strong winner on those engines.
Love those storiesI always stuck with Pennzoil, but I've run Castrol GTX, Quaker State, and some ultra cheap crap in my oil burners / leakers in the day. My '85 Monte Carlo used to burn a quart every 100 miles. I used to buy cases of Sunoco oil at ADAP Auto Parts for .77 cents a quart, lol. That car used to make people roll up their windows in the summer if they were unlucky enough to stop at a light next to my tailpipe. At idle, it pumped CLOUDS of blue out ... then when I jumped on the throttle when the light turned green, I couldn't see anyone behind or beside me. Good ol' days!![]()
Definitely not the Fram Racing. It is a high-flow, low filtration kind of filter. If you want Fram look for the Titanium which is good. The more common Fram Ultra Synthetic is OK, synthetix blen media like the Mobil 1. If I'm paying for a quality filter I want one with fully synthetic filter media. My current favorite is Wix XP.Which of these oil filters is my best option for any oil brand?
https://store.mopar.com/oem-parts/mopar-filter-p4452890
https://www.rockauto.com/mobil-filter
https://www.rockauto.com/fram-racing-filter
What about the Mopar black one? Is not good enough? I have read that it should be a high-performance filter. Planning to use Pennzoil or Amsoil. I don't know yet.Definitely not the Fram Racing. It is a high-flow, low filtration kind of filter. If you want Fram look for the Titanium which is good. The more common Fram Ultra Synthetic is OK, synthetix blen media like the Mobil 1. If I'm paying for a quality filter I want one with fully synthetic filter media. My current favorite is Wix XP.
