1 - 7 of 7 Posts
I've been told I need a new BCM. Where is it? Not behind the jocky box or kick panels, already looked there. HELP please !!!
Dodge calls it a CTM. It is located behind the driver's side lower plastic cover that faces the parking brake pedal. They are 30 bucks or so out of a junkyard.
Depends on the year.
It is on the passenger side above the kick panel (beside the glove box) on 98-00 IIRC.
correct on 98-99 right hand kick panel called a BCM
2000-2003 drivers side kick panel called a CTM
You can get a BCM from Junkyard or a CTM but dealer has to program it if your car has security key system
About $400 installed and programmed from dealer for 00-03CTM
you can buy a used one as long as you dont have the sentry key system, you will loose the keyless entry regardless unless you go to the dealer to get them relearned. i have two computers from A 98 just pay shipping and there yours
Still have them?
1 - 7 of 7 Posts
