1 - 1 of 1 Posts
Looking for some insight on a major question before I spend the money to find out it won’t work.
I currently have the factory headunit installed on my 16 R/T (originally had the Bears system) but have since installed a Maestro AR (amplifier replacement module) to run my aftermarket amplifier which is a Kenwood XR600-6DSP.
Recently iDatalink has released the Maestro Kit-DUR1 which will allow a consumer to install a double din aftermarket head unit. To properly install the kit you will also need a Maestro RR (radio replacement module) or Maestro RR2 so some other accessories to retain the Sat radio and warning chimes.
The million dollar question: Can I keep my current setup (Maestro AR/Kenwood XR600-6DSP) and add an aftermarket head unit with the Maestro Kit-DUR1/Maestro RR or RR2 and have it all work together?
1 - 1 of 1 Posts
