1 - 7 of 7 Posts
I have a 99 durango I have a, I believe front end vibration. I replaced
Upper and lower ball joints
Both hub assemblies
Inner and outer tie rod ends.
I took out my front drive shaft the vibration still occurred.
Any suggestions?
tires could be out of balance. Move them to the back and see if it follows.
CV joint or internal differential. My front diff had more of a howl then vibration. GL with fix
pull the front cover and inspect the gears. It sounds more like CV joints. what parts come with the hubs? maybe the axles going into the diff are bad?
I agree CV axles must be worn
1 - 7 of 7 Posts
