1 - 2 of 2 Posts
1999 Dodge Durango 5.2l
I am looking to diagnose this problem I am having with my 1999 Dodge Durango 5.2l as I get no codes from OBD2 reader but car won't start with check engine and check gauges lights coming on?? Perviously before car died out officially there was a problem when I'd press the brake my oil gauge would drop to zero and check gauges light would come on but as soon as I put foot on the gas oil gauge would go normal eventually one day a I'm driving and stop then car started sputtering out I pumped the gas and kept it going I made it down the block attempted same thing but no luck car shut off and hasn't started since only cranks up and eventually shows check gauge light and check engine light.. I changed oil pressure sensor and spark plug but still nothing.. please any information is great
See if it will start if you hold the gas pedal down just a little bit.
This sounds like a blocked idle air passage, bad IAC motor, or an old battery.
1 - 2 of 2 Posts
