1 - 2 of 2 Posts
My 98 Durango is having an issue shifting from 2nd-3rd gear and I would assume 3rd-4th. It won't shift unless I get the RPM up to 3x and shift into N then back into D. Then it's already shifted. I pulled the CEL code and it says "P0750 Shift Solenoid "A" Performance / Stuck Off" I've tried to ind a new solenoid but all I can find is the O/D solenoid and the govern solenoid and a TCC solenoid. Which part is it I need to replace and what's the part number?
Please help lol
It's a 5.2L V8 Auto Tranny
There are 2 on the valve body and usually replaced as a pair, as that is how the part is made, at the same time it behooves you to replace the filter and put in fresh fluid. Depending on your trans the o/d solenoid is 52118500 for the 42re or 4298221 or the 44re trans.
1 - 2 of 2 Posts
