8 speed Durango transmission fluid replacement (Very Important to change it ASAP)
1 reading
53K views 31 replies 12 participants last post by  Durango2017
Hello
Im new here
I just purchased a used Durango R/T 2014 with 124000 kilometer (around 77500 mile)
and I check the service schedule and the dealer doesn't change the transmission fluid
and when I called the dealer they told me the oil is lifetime !!!!!
the car run normally but I noticed when I slow down the vehicle I feel the transmission shifts with some shakes
I got my self to mopar parts shop
and they told me you need 6 quarts of oil (25$ per quart Mopar 8&9 speed oil)
and the panel around (174$)
when I change the oil in my favorite workshop
they use only 5 quarts and told me its full
I saw the different youtube videos and they all not the same amount of quarts
somebody used 4 another one used 6 and there is a BMW use 8 quartrs !!!!!!
the oil was so fucked up
I forgot to take picture im sorry I will return to workshop and give you I photo to missed up panel
the previous owner is friend of mine and he drove normally all the time without any towing or overloaded weight
the weather is normally 38°C ( 100 ° F)
I drove my car last night and the shift shake almost gone
so from my experience do not trust the dealer especially when the warranty outdated
Thanks for the warning,Feras.
They hold 6 qts, but 1qt or so remains in the torque converter. From what I learned from youtubes, a drain/fill will require only 5 qts.
But a flush/fill will require 6qts. There is a youtube of a transmission service instructor. I forgot the guy's name, or youtube handle, but he is in a wheelchair. As I recall,he did not recommend flushing the converter, and to drain/fill it. The level-check is bizarre on the 8HP70 tranny! It's more formal than a royal wedding.
I believe this is the one you are talking about.
#8 ·
I'm in the middle of this process now, but can't complete it until the half-shafts I ordered arrive, one has been on backorder for 6 weeks, Mopar says it should be next week.
I replaced the 3.09 differentials with the new 3.70's from the 2018 DSRT. After the diffs were in, I tried to install the rear half-shafts, but they would not go in all the way. So I looked them up and sure enough I had to order new ones, the front accepted the ones from the 3.09 without any problem.
I also replaced the plastic trans pan with the aluminum PPE pan which holds 2 extra quarts and the filter is replaceable. I have 10 quarts of ZF Lifeguard Fluid 8 standing by. While I was under there I also replaced the 2 quarts of ATF +4 in the transfer case.
Steve - what do you plan on doing about transmission shift points and things with the 3.70’s? Where did you source axles/diffs?
Phil, after I get it back together I'll log some data for Jay Greene, we were working on the Air/Fuel ratios before I pulled the trigger on the diff swap. The rear (68184732AB) I got from Rock Auto, the front (53010969AA) from Tasca Parts and the half shafts (4726090AC & 4726091AC) from OEMPartsQuick.com
Reactions: amelnik
How much do you think you have into the final drive swap? Did you do loaded carriers, I assume?
#14 ·
Dam steve talk about all in. those 3.70's are going to set you back in the seats
Phil, rear diff $1045 plus $37 for mounts, front diff $1065, half-shafts $700, replace single use nuts & bolts $125, total $2972.
MJB8, exactly what I'm going after.
#19 ·
Hello everyone,
I have a 2017 Durango GT with 43k, I had it for about a month now and everything was great till this morning. I drove the car and when I tried to put it in park this message came up (service transmission set park brake to prevent rolling) and nothing worked, couldn’t put it in park not even the brakes! Had to put the emergency brake on and when I tried to turn off the car only the engine turned off and nothing else! I unplugged the battery and everything reset but as soon as I drove it again and tried to put it in park and the same thing happened again! Anyone know what might cause this? And how to fix it? Please HELP!!!! Thank you
Chase300, when I stop the car and park it, I turn the dial into P but as soon as I do that the”service transmission set park brake to prevent rolling” message comes on and once that happens you can’t turn the gear dial at all! Also the actual brake gets really hard and you can’t use ur brakes, you have to engage the parking brake or emergency brake so it won’t roll. Also I forgot the check engine comes on and the red brake light also comes on, on the dash. And P will start flashing on and off! And last I think is that you can’t turn the car off all the way. The only thing u can do to get it back to normal. And I definitely don’t hear it go into Park.
#23 ·
There have been a few reports of the switch or controller causing this problem. If the issue is internal to the trans, the remaining powertrain warranty should cover it. Otherwise, appeal to them for a goodwill repair. Can't hurt.
#25 ·
I’m 99.9 % sure it still has the factory warranty so it should cover it (I hope)! Also I got the extended warranty on it too, bumper to bumper so fingers crossed!! I just wanted to see if there have been more issue like this and if anyone knew what caused this. I don’t want to go to the dealership and have them try to feed me some BS that it’s owner fault or wear and tear and they won’t cover it!
But I just want to thank everyone that replied to my post and gave me any type of info which is all helpful! I appreciate you guys taking the time to reply! Happy to be apart of this forum!!!
#27 ·
Possibly...there are however several...at least 2 in the shifter area and then you have them inside the trans. I just haven't dug enough into the ZF 8-speeds yet..though I see more and more shops are gaining overhaul and upgrade experience with them as they are used by several car manufacturers today.
You seem so have several issues that make it hard to point to just one cause. I'd like to see what codes you have.
#28 ·
If you have warranty, then off to the dealer you go. Hopefully your service contract is the factory backed MVP plan. If so, there should be no problem. The 3rd party contracts are a crapshoot from the get go.
#29 ·
Yea I’m pretty sure that when I bought the car it still had the factory window sticker and it had the factory warranty checked off. And I asked the sales guy and he said yes. And if there are any issues that auto dealership will have just met their worst nightmare!!!! Lol
