Hi everyone, I hope it is ok for me to share this info:
I had the same issue with my
8.4 Uconnect radio needing a code after a battery replacement. Here’s a quick guide to help you unlock it:
- Find the Serial Number:
- The serial number is typically on a label on the back of the radio. You’ll need to remove the unit to locate it.
- For some Uconnect systems, you can find the serial number in the settings menu under "System Info."
- Retrieve Your Radio Code:
- Every radio has a unique anti-theft code linked to its serial number.
- Dealerships can provide the code, but they usually charge a fee and require a visit.
For a faster and more affordable solution, check out this
Dodge radio code lookup tool. It provides instant code retrieval online—you just enter your serial number, and you’ll get your code right away. I used it myself, and it was quick and hassle-free.
- Unlock Your Radio:
- Turn on your radio and use the preset buttons to enter the code.
- Your radio will unlock immediately after entering the correct code.
Hopefully, this helps anyone dealing with a locked Uconnect radio. Feel free to reach out if you need assistance!
Mike
