5.7L to 6.4L intake manifold swap
72K views 108 replies 22 participants last post by  awehlage
I gathered all the necessary information by searching online forums, Facebook and YouTube. I really only found one general source for the Durango otherwise many installs were for the Charger, Challenger and Grand Cherokee. So I decided to compile all the information and make this post for my 2016 R/T. There are minor differences between all platforms which small modifications had to be made most notably dealing with the emissions control vacuum harness.
I did not do the complete install at one time. This actually took me a couple weeks as I was waiting for parts and did a lot of the wiring before I even swapped the intake manifolds. I would say I have a total of about 15 working hours. You could probably slap this on and have everything wired in 3-4 hours and functional but I took my time and made it look as factory as possible. I did more than the average person would based on personal preference (aka my OCD) which you will see in the pictures. Enjoy!
Parts needed:
•6.4L/392 intake manifold from any Dodge/Jeep/Chrysler SRT vehicle
•Short runner valve (SRV) actuator (05038529AC)
•Short runner valve (SRV) wiring pigtail (68064996AA)
•MAP sensor (68271094AB)
•PCV Valve Cap (05038532AA) *5.7L will not fit correctly
•MSD 8969 digital RPM window switch
•Painless Performance 70213 Cirkit Boss or 30/40 AMP waterproof relay
•In-line waterproof fuse holders (3) if using the 30/40 AMP relay
•Micro2 tap-a-fuse
•Air intake (OEM or aftermarket for 6.4L Durango SRT) or modify current intake
•20 gauge colored primary wire
•16 gauge colored primary wire
•Split wire loom (1/8”, 1/4”, 3/8”, 1/2”)
•Tessa tape (high heat exterior)
•Super 33+ electrical tape
•Adhesive lined heat shrink tubing
•Zip ties
•Soldering iron
•Ring terminal electrical connector
•3/8” fuel line quick disconnect tool
•Blue threadlocker
Optional:
•6.4L/392 engine half covers (05281359AA & 052813358AA)
•New intake manifold gaskets (Mahle MS19825)
•New throttle body gasket (Mahle G32511)
Swappable parts from the 5.7L:
•PCV breather hoses
•Throttle body (*I upgraded to a BBK 85mm p/n 1842)
•Brake booster vacuum hose
•Fuel rail and fuel injectors
•Oil filler cap
Wiring Extensions:
•MAP sensor (8”)
•IAT sensor (4”)
•TPS (16”)
Wiring Connections:
SRV connector clip (p/n 68064996AA) facing up L to R from the rear (1-2-3-4)
Pin #1 (blue) - Pin 87 on relay (blue)
Pin #2 (black) - Ground
Pin #3 (yellow) - MSD yellow
Pin #4 - Not used
MSD Box (settings: mode=1, on=4,400rpm-4,800rpm off=8,000rpm)
Gray - Not used
Black - Ground
Yellow - SRV Pin #3 (yellow)
White - Fuel injector ground wire (brown/dark blue)on cylinder #8 with green rubber water seal (forward most wire on injector connector)
Red - Relay Pin 87 (yellow)
30/40Amp relay
85 (black) - Ground
86 (white) - Micro2 Tap-a-fuse 12V+ switched accessory (fused 10A) - Fuse #76 ESP
30 (red) - 12V+ constant battery (fused 30A)
87 (blue) - SRV pin #1 (blue) 12V+ switched power (fused 10A)
87 (yellow) - MSD (red) 12V+ switched power (fused 10A) *Note: re-soldered yellow wire from pin 87a to 87 for (2) switched power outputs
Wiring and associated components:
SRV (short runner valve) pigtail
TPS (Throttle Position Sensor)
MAP sensor
IAT sensor
Sent from my iPhone using Tapatalk I
MSD rpm window switch & 30/40 amp relay wiring (did not use the cirkit boss because it was $85!!)
Custom bracket for the MSD
•1/8” ABS
•1/4” rubber backer so it doesn’t slap against the ECM
*3/8” mounting hardware
Wired up on the bench
In the vehicle
Fuel injector connection
Relay mounting
•Drilled a hole under the hood seal and used SS fasteners
Ground connection to ECM ground strap
Constant power connection to fuse box battery terminal
•30A mini fuse waterproof holder
Switched power connection
•White wire routed under the fuse box and through a small hole
•10A Micro2 Tap-a-fuse
#3 · (Edited)
Drilled and inserted knurled press inserts (E-Z LOK Knurled Press Insert, Flush, 18-8 Stainless Steel, 8-32 Internal Thread Size, 5/16 in Length - 4ZU14|240-008CR - Grainger)
•SS bolts and washers used to mount
•Didn’t want to rely on the OEM bolts in the plastic manifold for securing the throttle body. This is a much stronger mounting point for the throttle body.
New PCV valve cap made for the 6.4L
•It was blue (even though picture showed black online) so I threw some herculiner spray on it.
Intake manifold swap
Before (engine cover removed)
1. Remove air intake tube and disconnect all wiring harnesses and PCV hoses (*note I have a catch can installed)
•IAT sensor
•MAP sensor
•Throttle body sensor
•Fuel injectors
•Emissions control harness
2. Disconnect fuel line using 3/8” quick disconnect tool
3. Unbolt the intake (8mm bolts)
4. Disconnect vacuum hose in the back of the manifold
5. Remove intake, clean the cylinder heads and tape them up so nothing falls into your engine [emoji15]
6. Swap over the 5.7L fuel injectors/fuel rail onto the 6.4L intake manifold
7. Emissions control harness bracket will not fit on the 6.4L intake manifold so modifications needed to be made.
Before modifying. The bolt hole in the bracket and manifold bolt hole do not line up.
After modifying
•Last picture shows the intake manifold bolt washer had to be ground down to fit a little hump on the bracket.
8. Apply blue threadlocker into manifold bolt holes
9. Reinstall intake manifold bolting down to 110 INCH POUNDS NOT FOOT POUNDS
•Reconnect vacuum hose in the rear before bolting down
•Bolt on the throttle body. You can swap over your 5.7L throttle body but I upgraded to a BBK 85mm.
#4 · (Edited)
11. Install new air intake tube (ground off K&N logo and sprayed with Herculiner bed liner)
•K&N intake tube was purchased for the new 6.4L intake manifold as the old tube would not fit. I could have cut up the old tube but if I want to go back to stock I wouldn’t be able to use it. Called up K&N and they sent me just the tube from a 6.4L intake kit. To save costs I reused my Volant cold air intake box and filter. No need to spend extra money on a 6.4L Durango cold air intake!
**Volant does not make a specific CAI for the 6.4L Durango at the time of this post. So I guess that makes me the first?!?
12. Recheck ALL connections, turn the ignition to RUN (not start) to prime the fuel rails and check for fuel leaks.
13. Start engine again checking for anything out of the ordinary.
14. Rev the engine and enjoy!!
*I do have 6.4L half covers but they need to be trimmed to fit.
I am also grinding out the “powered by SRT” and putting something custom on there like this:
My OCD kicked in because if the factory had split loom I replicated on the extended wiring harnesses. If the factory used exterior fabric tape I used the Tessa tape. I tried to make it look nice and neat as best I could. If you have questions please ask!! Can’t wait for a dyno tune [emoji594]!!
Nice clean install. Have you noticed a difference before getting tuned? Where did you get the intake?
Thanks!
You can notice the low end torque with the long runners for sure. Feels stronger coming out of a stop. I have to take a longer drive to get the short runners activated but most people who have done the swap say they don’t feel the horsepower increase on the top end as much as the torque increase on the low end. I also have to dial in the MSD RPM window switch setting that will be the best through a tune.
I got the intake off eBay (used) from a 2018 Dodge Charger with 18K miles. It came with everything I needed except for the PCV valve cap and SRV wiring harness. I looked for a while to find one that had most of the components still attached and not stripped down. It even came with the 6.4L fuel injectors, which I thought about using since they would push more fuel but I decided to stick with stock and resold the 6.4L injectors to offset the build cost. Using the 6.4L injectors would have required a tune immediately as the engine would run too rich and I don’t get a tune until December. The 6.4L injectors would have provided an increased HP gain though...[emoji53]
Yes, I will have to trim the drivers side cover for sure! Possibly the passenger side because of the large gauge power wire/wiring harness cover that crosses over the throttle body. I am going to use these pictures I found for reference and trim a little, test fit, trim a little, test fit, etc.
Let’s see your install!!
#28 ·
Ok, gotta show this to anyone doing this. It's only available from Modern Muscle Xtreme.
Reactions: zwade and amelnik
#32 ·
I was watching Richard Holdener doing dyno testing of gen 3 hemi's and he mentioned that 2017 and up 5.7's also got a dual runner intake, it came on Ram trucks. I checked and it's true! I've been trying to buy a 6.4 intake for almost a year now but it's either not available or too much $$$. Well, we have another source and it's cheap. I quickly checked eBay and got complete one that included TB injectors and the switching solenoid for the runners for $320 shipped. I've since found them for around $200. I got motivated by this thread and will be installing it as soon as I get some time. Just need to order new gaskets.
Will probably also do some light clean up on the ports, since it's all open now.
Only thing is I'll have to redo my cold air again, since on Ram TB is pointing up instead of forward. Not a big deal.
Also, I'll check out that controller posted earlier but I did see an option for short runner solenoid when looking through OBDAlfa options, so may looks at that as well. I have HPTuners ECU, so I should be able to adjust switching through there in theory.
#33 ·
Keep us posted on the RAM 5.7L intake manifold swap. Also, I have HPTuners and didn’t see anything there which I didn’t think I would. Try to find a wiring diagram for the RAM to see where the SRV is wired to the vehicle to integrate possibly into the ECU. I think it would be hard to activate a feature that didn’t originally exist as an option for the Durango 5.7L platform. I like your thinking though!
#37 ·
So you went with custom fuel rail and vacuum lines? You've outdone yourself once again. Great looking work. What's the part numbers for those?
Engine half covers trimmed, painted, “HEMIfied”, purge valve relocation and new 6AN fuel line fittings with braided nylon hose. 5.7L to 6.4L intake manifold swap complete [emoji736]
Passenger
Driver
VHT GM Satin Black High Heat Paint
#39 ·
Super cool seeing someone else who swapped in a 392 intake manifold! I'm really impressed that you did all the work yourself. I had initially started in on it solo, but wound up running out of time for a variety of dumb reasons and just had the performance shop do the heavy lifting for me. I'm glad that I did, given my total inexperience with wiring. Your project turned out great!
#41 ·
Thanks! I’m a true DIYer plus knowing what a shop would charge me would be crazy. Plus the less hands that touch her the better!
#40 ·
Update: replaced the custom 6AN/braided fuel supply line with an OEM MOPAR 392 fuel supply hose. Was having some issues with the startup fuel pressure. My assumption was the rubber fuel line wasn’t keeping a consistent pressure upon shutdown so the startup wasn’t pressurized like it should be. So much for being cool [emoji41]!!
#55 ·
So, I measured up the RAM intake and there is indeed very little rom on top, not with stock hood anyway. I'm going to investigate rotating or even cutting off the elbow and gluing or hot-welding the throttle body flange to the intake directly.
Alex...
Just a little update. I think I've found a more "simple way to do the RAM intake under Durango hood. I was going to cut the elbow and glue the flange like our stock. However last weekend I was able to do some more measuring and thinking about the issue and I've come up with an idea of making an elbow with a flange that will bolt up to the intake instead of the throttle body and will move throttle body to a better position. This leaves plenty of clearance to close the hood and also has the effect of increasing the plenum volume. I have the 4" elbow and pipe left over from when made the cold air for the larger throttle body, so just need to order some aluminum plates for the flanges. If I get the parts by this weekend, I should be able to tig something together next week.
#50 ·
Well I got rid of the MSD Window Switch setup in favor of using my unlocked PCM and HPTuners to control the SRV. Used all factory plugs and terminals. Fully integrated without any aftermarket parts! BTW MUCH cheaper than any aftermarket setup if you have a tuned PCM.
Details:
SRV connector clip facing up L to R front rear (1-2-3-4)
Pin 1-Red
*Fused ASD Relay Output BN/YE (PDC C3:pin 7) 16 gauge 20A inline fuse
Pin 2-Black
*Ground BK (PCM ground strap)
16 gauge
Pin 3-Green
*SRV Actuator Control Signal DB/GN (PCM C2:pin 53)
18 gauge
Pin 4-Blue
*SRV Sense Output DB/YE (PCM C2:pin 60)
18 gauge
Routed the wires following the yellow line. Through the black plastic cover at the front of the engine, under the engine cover between the fuel injectors and coil packs then behind the intake manifold to the SRV.
#51 ·
How is that working out? Looking forward to a follow up on this
Does the pcm need to be unlocked for this to work? If you're just splicing into existing wires, can't it work with the oem pcm?
Details:
Pin 1-Red
Pin 2-Black
16 gauge
Pin 3-Green
18 gauge
Pin 4-Blue
18 gauge
#58 ·
Huh? English please.
#60 ·
If you reread what you posted before you will see that it made no sense. Just follow that thread and you will see the places he had to cut. If you aren't making any other mods to your motor then chances are that you won't need to make any cuts to the covers but you won't know until you test fit them. It's when you add parts from SRT motors or add an oil catch can that you might have to make some cuts. Keep in mind that the thread you referenced was for a motor with a 392 intake manifold, not a stock manifold.
