I'm at 140k miles and would like to avoid pulling the transmission. Does anyone have experience with slip-in bands?
https://transmissiontechnologies.com/slip-in-band-46rh-46re-47rh-47re-48re-a727-a518-a618-ezn-flex-kickdown-chrysler-dodge-62-up-carbon.aspx
https://transmissioncenter.net/shop/slip-in-band-fits-48re-47re-46re-727-all-1962-up-change-without-pulling-the-transmission/
Will the heads of the old one need to be grinded off? I guess the ends of slip-in bands must be flexible to be pushed or pulled through tight spots around the drum.
I had slippage between 1st and 2nd, did not adjust the front band in time and the piece between the adjuster and the band fell down and blocked the space for the reverse gear actuator.
Found this chart in an old post:
