1 - 3 of 3 Posts
Hello, Newbee here
The wife bought a 2003 durango with a blown motor.
We have replaced the motor with a remanufactured 4.7, new injectors, throttle body cleaned, all sensors replaced and before I can even drive this thing I get the the dreded P0121 code, TPS. I have bought autozone and dealers one and neither work.
Nothing I have done will get this code to go away, the vehical will not keep idle, I have check the voltage at the T/B and all checks out.
I'm already tired of this thing, not sure what to do. It sound like this is a common issue.
Any info on what to do next would be great.
Thank you for reading.
Adam
Checking my list a P0121 can be either "TPS Voltage Does Not Agree With MAP - TPS signal does not correlate to MAP sensor signal." or "Accelerator Position Sensor (APPS) Signal Voltage Too Low - APPS voltage input below the minimum acceptable voltage."
It may be worth checking the MAP and APPS again, just to make sure.
the MAP sensor is new, not sure what the Accelerator Position Sensor APP is. will need to look for that.
thx for the reply. TPS? I have tried a total of 3 and all the same readings.
1 - 3 of 3 Posts
