1 - 3 of 3 Posts
I’m about to get the 22” Rohana Rfx11 wheels but wanted to know if anyone has advise on the size of rim?
I was thinking 9 for the front and 10.5 for the back but I don’t want the wheels sticking out at all from the body. Good size?
Looking at your other posts, it appears you have an R/T - I assume it is AWD. If so, your AWD system requires a very close match for both circumference and contact patch between all of your tires. Failure to keep them close can cause strange behavior and potentially significant damage to the system. There is virtually no way to keep these values within spec on a staggered setup between your front and rear axles. I would stick with the same wheel/tire size on all 4 corners.
1 - 3 of 3 Posts
