Hi everyone. I am new to the Durango family but seasoned in car audio. I recently got a 2022 Durango RT TnG, Blacktop Package with the HK audio system .
The last vehicle I had to do research and make custom harnesses and dash kits was for the 2019 Ram (5th Gen). Well, here I am again back at the drawing board. Seems Stellantis has changed the 2021-2022 Harman Kardon setup with the new 10.1" screen compared to 2018-2020 setup.
I have been scouring online groups and making calls to people I know in the audio industry and this HK setup seams to still have limited information on adding speakers and amps without much issue.
I will post specifics as my research continues but it seems that iDatalink nor PAC have a plug and play module yet. I have spoken with both of them on the phone. iDatalink has no plan or idea of when they will update software for Maestro AR or the DSR1 modules. PAC unofficially stated that the PAC AmpPRO AP4-CH41 R.2 works but some wires need to be hardwired into the factory wiring. Since I am not a shop, they would not specify what these need spliced in to.
Based on what I have found, I plan to use an Audiocontrol LC8i at this point for integration. I have read that these did not do well with the Beats system but it also seems that many things didn't work well for integrating with the Beats system.
Speaker output wires located at the amp so far (will update with color code later):
Middle/Little Gray connector has the following outputs
Top/Large Gray connector
Another thing I have noticed is that these doors resonate like crazy, so I put sound deadening on the plastic inner door panel, the inside of the door as well as the main door panel. This helps tremendously but certain bass frequencies still cause some resonating so it would seem I need more deadening material. Other panels vibrate as well but I have not gone through the whole vehicle yet.
I have installed speakers in the center and both front doors. It seemed to increase some cabin noise at certain RPMs so then I also disabled the ANC (I think) using the bypass harness from my 2019 Ram I used, before adding an aftermarket radio. But this did not seem to make a difference.
This brings me to some questions and hopefully someone can chime in on this thread to assist.
Questions I have:
1. Does anyone have the speaker/ANC schematics for the '21-'22 HK system?
2. Anyone here familiar with what's required in regards to PAC harness setup needing hardwired?
3. Has anyone else gone down this path completely yet and can offer some further assistance?
I appreciate any input you may have.
- Front left and right door tweeters
- Front left and right door 3.5" speakers -- possibly tied into the door tweeters as there are no dedicated wires for these
- Front right door 6x9
- Center 3.5" speaker
- Front left door 6x9
- Back door left and right 6 1/2 speakers
- Back door left and right tweeters -- possibly tied into the 6 1/2s wiring as there are not dedicated wires for these
- Left and Right Hatch area 3.5" speakers
- Both sub outputs for sub in storage compartment
Questions I have:
