2021 Durango Pursuit - 18" Steel Police Rims and Chrome Center Caps
57K views 104 replies 19 participants last post by  Urbish
Does anyone know the source/part number for the steel rims used on the 2021 SSV/Pursuit models?
UPDATE 27OCT2021
Here are the part numbers with links to buy so you don't have to read through the entire thread:
The steel police rim p/n is: 6ZW73DX8AB
The police center cap p/n is: 6ZQ88SZ0AA
The TPMS (433 MHz - 2011? and up DD) I used is p/n: 68252495AC
The TPMS nut p/n for above is: 56053033AB
Dorman aftermarket lug nut (much cheaper than Mopar and retains hubcap the same way): 611-979
Cooper Evolution Winter Tire in 265/60R18
Add all of that up and you'll get this (my 2018 DD R/T):
#74 ·
This is what I'm thinking as well. Even though the Mopar site says the wheel is compatible with SRT and SRT Hellcat, I asked for more info from the local Dodge parts department.
Apparently the parts system can look up these wheels, and it actually lists the compatible brakes.
I have a 2021 SRT 392, standard Brembo brakes (not the upgraded 2-piece rotors).
After checking my VIN, parts confirmed that my SRT brakes are not listed for this steel wheel.
Of course I will be happy if they fit, but it doesn't look like it.
#76 ·
The 2021 DD Pursuit center cap I ordered came in yesterday. It is 2" smaller diameter than the old style dog dish cap. I will get cranking in CAD to see if I can meld the two designs for a retro looking cap that fits the new wheels.
The new one snaps onto large bosses of the open end lug nut. I looked at ordering the Mopar lug nuts but they list at $11/ea. I instead opted for a two packages of the identical Dorman 611-979 for $19.35/pkg of ten from Walmart.com.
116872
116873
116874
116875
116876
#77 ·
So I have my snow tires on hand and everything else I need except the stinking nuts that hold the metal valve stem TPMS sensors in place. They are back-ordered, but should be in soon. I went with the TPMS sensors with metal valve stems since the rubber stemmed ones stipulated that they are for 20" wheels only. Not sure why...
I ended up buying a set of Cooper Evolution Winter tires in 265/60R18 from simpletire.com. This thing should be a beast in the snow. I ordered them early as I don't want any COVID delays getting in the way of my mobility! Unexpectedly, these tires were made in Tupelo, MS.
117027
117028
#79 ·
Ordered wheels from my dealer and they came in today. Took about 2 weeks since I ordered. Still need to get tires, center caps, lug nuts, and TPMS sensors. Did you get the sensors with the metal valve stems yet? Wonder if the ones with rubber would work since they are slightly cheaper
Nice! I got the TPMS with the metal valve stems and have them in hand. The metal ones have an adjustable angle between the valve stem and the rim allowing you to position the sensor flat against the inside of the rim. I've been waiting on the nuts to secure the valve stems (they do not come with the valve stems) for over a month. They should be arriving today or tomorrow (ordered from mopar online, fulfilled and shipped from my local dealer parts desk). Then I will have everything I need to get my tires mounted.
FWIW, the dog dish caps DO snap on to the original chrome (closed top) lug nuts without issue, but I imagine they would scrape the chrome off over time and harbor moisture and salt during the winter, so I would still recommend a separate set of the Dorman lug nuts I mentioned above. The chamfer angle and the OD of the top of the chamfer that the hub cap attaches to is the same for both the chrome nut and the aftermarket.
#82 ·
That's a nice alternate look.
Reactions: Urbish
#84 ·
Looking good! I'm finally getting a winter set for my 2013 Durango. But I'll be running the 18x8 steel wheels for the full size spares. I plan on going with 285/60/18 BFGoodrich All Terrain T/As. Would these caps still fit those wheels?
How is adapting the old school dog dish cap coming? I plan on doing that to mine. Was hoping to paint my steel wheels body color(True Blue Pearl) and having the old school chrome caps.
Thanks!
Mitchell
#103 ·
Ha Ha. That's like a first grader asking the teacher where the front of the line is.
