1 - 20 of 36 Posts
Tried searching forum but didn't see much on this issue.
Just got myself the new 2020 Durango with the H/K 19 speaker package. The sound is very weak and the bass almost does not exist. I've read elsewhere people have come up with solutions and such but I haven't tried any of them. Has anyone here had any problems or found ways to improve the sound. Coming from my F150 HD that has very amazing sound and bass to this has left a bad taste in my mouth.
The exact same complaint in the new Ram world as well. The HK leaves little to be desired. The alpine system is perfect with the subwoofer.
Ram has had updates to their HK systems but owners are still less than enthused.
I took in into dodge and was told by there, very old rusty looking radio guy, the sub is on, he could feel it bumping on the enclosure where it's stored. When I asked him if this all sounded like a $1000 upgraded 19 speaker system with a 10" sub he went mute. Said bring it back Tuesday and they will check it all out. I'm about to take it to a car stereo store and see what they think.
There are updates for the HK for the Rams. Maybe they can cross reference and see if there is one for the Durango.
I have a 2019 Citadel with the same issue. Dealer shaped out the system with a new one and the results were the same damn thing! Dull sound with no bass! Chrysler tech did research on the problem as an elevated service issue and the reply from Chrysler was that the system is performing as designed! DON'T PURCHASE A DD WITH THIS SYSYEM IN IT AS YOU WILL BE COMPLETELY UNHAPPY WITH THE SOUND AND AROUND $995 lighter in the wallet ! ! !
2020 DDSRT
Is this an across-the-board issue, or hit and miss? I just ordered my DDSRT two weeks ago with the upgraded HK system.
I'd guess all of them, it's "working as intended" per Dodge but is sorely lacking in bass. The Alpine system sounds a lot better IMO.
Howdy, just picked up a left over 2019 R/T with the HK system, I think it sounds fantastic. The source definitely matters, XM channels for instance are compressed, so the dynamic range is limited. Pandora sounds much better, to me. In some ways the system reminds me of Bose in that there is a strong logic built in to reproduce the sound accurately, as it was recorded. What I mean is a country song for instance isn't going to hit like hip hop does. I think the big thing the 825 watts allows for is accuracy at high volume. Most people think it lots of punchy bass and artificial highs are what sound good, but engineers think otherwise.
Discussion Starter #11
There's no doubt it sounds amazing, I just feel it's underwhelming in the bass area. If there is a 10" sub in the back, I shouldn't have to find the perfect source and max the levels out to hear it. I have played some music from my phone and it sounds perfect. Highs are good, bass is there. But it has to be the right song. Happens about 10% of my music listening, and my playlist has all genres almost. But something else that irks me is if I am listening to it at a low-mid volume, the lack of bass even from the rest of the speakers is so low, it sounds like a cheap pair of headphones.
There is another thread on the fact that surround sound is not functional on Sirius/XM on the HK systems. 2020 Durango surround (Amp) sound wont go on with sirius I found that playing music through my phone Sirius/XM app and Android auto sounds a lot better. I also found that I need to set the volume at around 17 versus 13-15 on the Alpine or Beats system to get quality sound and bass.
You must have a defective system or something because mine sounds amazing! I just got a new 2020 rt Durango last Saturday from the factory in Canada and I love it. Although it seems to be louder when the engine is off and the car is set to on. Not sure if that’s because of the motor noise or what. I was listening to xm today and bass sounded loud. Had to lower it to 5 when I usually have it on 8. Not sure if there might have been a update or what.
My car was just manufactured last month. It’s a 2020 Durango rt blacktop and the hk sounds amazing. The subwoofer hits way harder than my beats System did by far.
source makes the difference! XM is horribly compressed. Most internet streaming is compressed as well. HD-radio - yup compressed.
If you want a good source you either use the aux in to a good music player, a CD, or USB-connected source playing uncompressed audio files or at least 320kbps 16-bit MP3's. With good sources I get good sound.
I did 2 thing:
1) I copied my 320 kbps MP3 music library to a USB stick and played it from that (this had some problems including a very long time for the HU to read the catalog, inability to parse certain characters in files and ignoring songs, random play only picking a handfull of songs to randomly play...etc)
2) uploaded my entire 320 kbps MP3 music library to itunes and play my library through my phone. This is NOT the same as just using itunes which uses lower quality settings. This of course required a good 4G cell reception and an unlimited data plan.
I use #2 now as the USB stick along with my phones plugged into the HU was causing intermittent electrical problems....but yeah it sounds fine as long as your source is of high quality.
The H/K system in our ‘20 Citadel is horrible. It’s genuinely uncomfortable to listen to at reasonable levels.
It’s really aggressive in upper frequencies, especially between 4k and 8k, but the high band on the ridiculous EQ only seems to affect 16k and up, so you can’t tame it down. The frequency ranges affected by all the EQ sliders seem crazy narrow, so the midrange slider does nothing to help, either. And there’s some bass, but the low slider appears to be mainly focused around 400Hz or so, just from a seat-of-the-pants (ears?) reading. For example, Audioslave’s “Doesn’t Remind Me” has nearly zero bass, and the low EQ slider does essentially nothing to help.
Did I mention how underpowered it is? No real volume until it’s 1/2 way up. Speed adjusted volume and surround are both off, and enabling them doesn’t help. Source is an iPhone 11, locally-stored tracks in Music from Apple Music. Should be more than good enough, and they sound really quite good in my ‘19 Sonata, ironically with the Infinity system, as well as my ‘15 Wrangler with a Sony CarPlay deck and factory Alpine system (which actually has its own issues, but the EQ in the Sony deck has largely tamed them).
So, yeah. Not pleased. Good thing it’s not my DD (wife’s truck, she listens to talk radio and doesn’t care). I’d be really angry.
2020 Durango Citadel AWD, 3.6
Im not sure if this will help but the earlier version in the 2014 had the reverse problem it added to much base. There is some type of sound processing built into the system . The eq will throw off the entire audio output depending on what volume lts adjusted at. The work around has been to find a middle ground that sounds good and not adjust the eq at the higher volume levels. Try adjusting the eq at lower levels then turn the volume up adjust the eq bands up or down see if it does the opposite of what the adjustment is designed to do. I have built at least 20 multi amp sound systems in my cars and boats and this system sounds decent when adjusted correctly
I have the same issue. We just our our 2020 R/T Durango in August with the updated HK system. There is just no richness, no bass. I just got back from the dealer and they said that it is a known issue and that Chrysler is waiting for a fix and it should come when there is an over the air update. I'm a little annoyed that some systems seem to work and others don't. For a brand new car, they should take care of the issue. Or if there is an over the air fix, shouldn't they be able to upload something to the system? And if there was an issue, why didn't the sales department let us know about the issue? Feeling a little annoyed.
How could there even be an OTA or software update that will "fix" the issue? If that were the case, that means there's some sort of secret sauce signal processing that is happening behind the scenes that the user can't directly control through EQ or cross over settings and if that's the case - that's the problem right there.
The only solution I'd want on a $1k system is the ability to turn off the DSP and manually adjust the EQ.
I’m shopping for a ‘21 now, and am actively looking for one without the HK audio. My folks just got a ‘20 Grand Cherokee, and the Alpine is much less shrill and less fatiguing to listen to. A bit muddy, but better to my ears.
1 - 20 of 36 Posts
