So about two weeks ago I needed to replace the alternator and starter on my Durango so I did. Now two weeks later this happens randomly, I’ll get in to start it and it doesn’t start on the first try and the engine light comes on. Then on the second try of starting it, it works. So I’m not sure what’s going on could something be loose that they fixed and that’s why it’s causing it not to start right away sometimes?
So the alternator and starter both died at the same time. Hear what I am saying . . . they usually both do not go bad at the same time.
Hopefully they were actually changed. Needed or not, you got new ones under warranty. See what I did there, I found a positive.
However, a dead battery can make you think a starter is bad. So, hopefully a charged battery is not what really fixed the problem due to an accessory left plugged into the 115V inverter overnight. Sorry, I could not help it. I try to be positive.
Also, the above issues have nothing to do with your delayed startup issue that resolves itself with two startup attempts.
The need to have two prime or start cycles could be caused by a few things. I would have them start with checking your fuel pressure at startup.
If they do a prime cycle like
Tin Foil Hat suggested, they should see the pressure build to 58psi and hopefully it will hold for some time. If it is dropping immediately after the prime cycle, then it is bleeding off the pressure. The pressure regulator, fuel pump check valves, and injectors all try to hold the pressure when the pump is turned off but the seals are not perfect and eventually they will leak down over time. Larger or faster pressure leaks usually start with the pump check valve or pressure regulator in the tank. The two prime or start cycles is usually a workaround for this.
The age of the pump, pump supply voltage, fuel filters, gas contaminates, and low tank fuel level operation all can affect pump performance and reduce the pressure build up speed needed before each start cycle, especially if you have leak down. Also, with the heat of the engine bay, some vapors may form in the fuel rails that may take time to purge.
A stuck open check-valve on the fuel pump will only affect the pressure holding when the pump is not running. Once the car is started, it is not a problem. Some performance pumps eliminate the check valve as it can be a restriction. The same goes for the pressure regulator in the tank fuel pump assembly or basket. However, if the pressure regulator leak gets really bad, it could be and indication that the pressure regulator is beginning to fail. I had two of them fail where my car would not start at all because the pressure would not go above 20psi. You need a minimum of 40-42 psi to start the vehicle and it may require starter fluid at that low pressure to get it going.
Unfortunately, the fuel system prime cycle time cannot be increase from 3 seconds and most people will not fully utilize the prime cycle and will press the brake before hitting the start button and not wait 2 seconds of prime time before hitting the brake to start the crank cycle.
Other mechanical and electrical components can also affect the start. However, I recommend looking at the fuel pressure first before listing every other possible cause. Hope this helps!
