1 - 20 of 26 Posts
I could not find much information on where to set a floor jack and jack stand while lifting the front of a Durango, so I thought I would post a few pictures I took of the lift points I use when I am lifting the front of my 2018 SRT Durango.
The pictures are pretty self explanatory but I place my floor jack pad under the end of the cross member bolted to the subframe, right behind the designated front lift point (arrow on rocker panel). Once the vehicle is lifted, I place a jack stand (with pinch weld adaptor) under the designated front pinch weld lift point.
108234
108235
108236
108237
108238
108239
Reactions: mamasboy
I would suggest you not use that point for jacking., Here are some threads to read. I had to replace bothe brackets because they were used to jack the 5500lb SUV.
https://www.dodgedurango.net/threads/drivers-side-front-end-creaking.70118/#post-713550
Reactions: Ollie Crow
Hes not using those brackets.
Thanks for the post and pics Booky. Helps me out. Need to find me some of those pinch weld adaptors
Discussion Starter · #6 ·
Did you even read the post or look at the pictures???
Discussion Starter · #7 ·
I sure did and you can do anything you want, I was just warning you.
Discussion Starter · #9 ·
You do realize the bracket mentioned in those threads you posted is completely different than the crossmember I am showing in my pictures, right?
Got it you're on the trans support extension. So why not just jack it up on the pinch weld and use a block of wood just behind that bracket for the jack stand?
I bought the SUV used, the owner before me or where ever he had it serviced bent the bracket.
My apologies Steve.
Again thanks for all the info Booky. Im a floor jack mechanic too. Since the wife bought her R/T and the little work I have done on it has made me research using floor jacks and stands. Cant bring myself to lifting it by the pinch welds. Those pads are the ticket!. I have used the front lower control arm for jack placement but that leaves no other spot for a jack stand. Anyways thanks again
Discussion Starter · #14 ·
I have used the pinch weld to raise up the vehicle, using a ZL1 addon pinch weld adaptor on top of the floor jack pad (shown below). It was more difficult because you have to maneuver the floor jack and slowly raise it up into position so you do not damage the rocker panel.
Then as Chase300 stated. you can place the jack stand under the subframe.
Lifting from the crossmember/subframe was much easier with no worries of damaging the rocker panel.
108246
Booky could you please show how you lift the rear end of the DD when you get around to it?? Great job!!!
Preben
Discussion Starter · #16 ·
Preben
Sorry it took so long. Rear lift point with jack stand at pinch weld:
108322
And here is where I set up on the Front passenger side, which is the same area as the Front driver side except there is no cross member at this location.
108323
Reactions: pridbor
Saved images for future reference!!
Thanks !!!
I don't have any pinch weld "adapters" or whatever might be helpful but I'm also trying to figure out where to jack up my durango in the front from using a floor jack. Is this pic a place that'll work OR should I move the jack a couple inches closer to the rear of the vehicle so that it's NOT on that black, bolted cross member? Sorry, I get confused by this stuff. Thanks a lot
Hood Automotive tire Tread Tire Motor vehicle
1 - 20 of 26 Posts
