I did a search and there are tons of posts on hard shifting and my issue seems just a bit different.
I have noticed a hard shift from 2-3rd. I figured it was because the transmission was cold. It only does it once then it's fine for the rest of the day.
Yesterday it shifted and it felt like a slam then the check engine light came on. The transmission was stuck in 3rd gear and wouldn't shift up or down. The paddle shifters wouldn't work either. The transmission would shift to park and reverse. I pulled over shut the engine off and restarted the car. The transmission worked after that. I got the check engine light cleared but the mechanic said he didn't see any codes.
Any clue what's going on? This thing is about to find its self sitting on a car lot if it doesn't straighten out.
