I have.why did it have to be jump started? could be a clue..
did you ever find the problem, I’m having the exact same issueI have.
I have no idea there is adequate voltage throughout the vehicle and all of the Electronics work 100% just won't turnover until a direct Battery jump is connected.
2016 Dodge Durango Citadel 3.6 , 50k miles, got a new battery and alternator and new fuse box and still nothing,Kimberly:
Welcome to DDN. Year, model, engine, and miles on your D please? Have you had the batter(ies) load tested to rule them out?
What’s a secondary power source, and does that mean I need a new starterIf you can hook up a secondary power source, and it works, then it has to be problem in the chain between the battery and the starter. Some Durangos have had issues with relays in the starting chain.
Ok , yes we did that and it started right up at first but when we took the cable off it fell dead and now it won’t do anythingSecondary power source as in jumper cables to another battery.
