Can someone please confirm the cylinder numbering?
I.E. front to back, passenger side is 2, 4, 6
Front to back, driver side is 1, 3, 5.
I've got code P0204 injector circuit open cylinder 4, and P0304 cylinder 4 misfire detected.
We have an extended warranty so, took it in to dealer. They said a rodent ate some wiring. That is not covered.. They proposed to change spark plugs and tape up the harness for $800+.
They also said the water pump is leaking. That will be repaired under warranty.
I picked up a set of NGK 7751 laser iridium plugs and a Fel Pro upper intake gasket set so I can tackle the job myself.
