Here are the plans, and I'll update as I make progress.
Rationale: While HID headlight bulbs are pretty good, I've had a lot of success with LEDs on other vehicles. I like the high output and low power draw. My interior is black, and the interior lights just aren't bright enough for my liking. LEDs put out more light, which will be useful here. Form follows function- I am doing this for added light output, not for what it looks like.
Exterior:
a. Headlights- convert HID to LED. I don't use cheap LED bulbs here, they tend to scatter light and blind oncoming traffic. I read test sites such as bulbfacts and another one on YT that actually test the bulbs and involve real people, not stupid computer voices.
Status: Completed, used "Sinoparcel D3S/D3R Bulbs +500% More Brightness - 6000K 35W High Low Beam Xenon HID Replacement Lights - Pack of 2" bulbs specifically for this purpose. I see they are no longer sold on Amazon, but there are other similar HID to LED conversion bulbs available. The manufacturer still sells them here. Have not road tested yet, but they look good in the shop. These were $73/pair and were plug & play.
Pics: Pending outdoor use
b. Fog lights- convert to LED (H11). I want a pattern that will compliment my low beams, I don't plan to use these with high beams as they serve different purposes.
Status: Parts on order. I am trying 2x different brands I found on Amazon.
Pics: Pending
c. Tag lights- Swap out OEM LED for multi-LED. I used these found on Amazon.
Status: Completed. Note- Easy swap, most difficult part was getting old connector off.
Pics before:
After (new one on left, old on right):
Interior:
a. Overhead, under dash, and rear hatch- replace with "194" LEDs. I'm trying these from Amazon.
Pics: Pending
b. Visor lamps- replace 29mm incandescent with LEDs. I used these from Amazon.
Status: Completed. Note- I found they were too bright (glare) when faced backward, so I rotated each one about 90 degrees. More light w/o the glare.
Pics before:
After, rear facing:
After, rotated:
Exterior:
Pics: Pending
Pics before:
Interior:
Pics: Pending
Pics before:
After, rear facing:
After, rotated:
